I Bought from HS18 Rs.3000+ 150 SC.
Advantages
1. DATA and Voice free for 3 months.
2. Very low cost in 4g mobile.
3. Also working jio play all tv channels. 40 HD channels. and totally 289 channels are free for 3 months.
4. you can you as wifi hot spot though this phone
5. You can connect PC and labtop though usb cable working like wired broadband without reduce speed.
Disadvantages.
1. Battery problem even one day not possible if you use 4G.
2. 4G speed uneven in my area.some timed 26 mbps some times 4 or 8 mbps.
3. Heating issue is there normally.
4. Google play store not available.
5. You have to download through LYF store only.
See the Sunmusic live channel working fine only 33 second difference.
Advantages
Disadvantages.
