JIO 4G -JIO tv connected to LED tv like DTH.
  • Thread starter Thread starter sasitnj
  • Replies Replies: Replies 40
  • Views Views: Views 21,795
sasitnj said:
Yes possible VGA cable (monitor cable) connect to LED tv through PC input. Sound you have to get through PC  speakers.
Bro I am having that option also but my question is I have connected Adtv to Tv via HDMI and Can I use that cable to connect to PC
abhi1276 said:
Blue stacks is a worst app for ram eater and make your pic and laptop a sh#t with hang and very slow to get upload if you have less then 2gb ram it's only good if you have good configuration laptop or pc atleast  4gb ram to work perfectly or you require graphic card to work with less then 2gb ram.
I have 4gb ram, no issue for JIO tv play.
Not possible through PC via HDMI.
Dear sasi ,
I am not able to connect with laptop.
I have also tried blue stack.
graphics card not supported
Karthik said:
Dear sasi ,
Which labtop? mine Lenovo working fine.
Karthik said:
HP laptop
If you have 4gb ram, then its possible to download. Even my PC also bluestack download successfully. Pls re-check other options in settings.
