Planning to Purchase 32 inch LED TV
  • Replies Replies: Replies 53
  • Views Views: Views 6,020
anubhav said:
Hi,
The model u selected is good I myself had shortlisted it while i was buying tv last year, but it's actually 2015 series model and now samsung has launched the new K series 2016 like the 80cm (32) HD Flat TV K4000 Series 4 | SAMSUNG India
80cm (32) HD Flat TV K4300 Series 4 | SAMSUNG India
as these are new launch the prices are not shown as of now
And the most important do visit a samsung showroom and compare the quality and features between the J and the K series to get a better idea.
bro, how's K5100 samsung led tv it's full hd tv, pls do check online and let me know. thanks
vijay mahanta said:
Buy VU 40 inch led at just 2100/-
40 inch tv at just 2100rs... Unbelievable :skd :u
Bro its the same as k4000 series, except the screen size i.e 40"-43" and its full hd, also k5100 tvs have higher pqi at 200 whereas k4000 has 100
So definitely the picture quality and upscaling will be much better.
so bro should i go for it, any more things i need to be kept in mind ? bro whats pqi?
Pqi refers to samsung's own picture quality index, the lowest is 100 and the highest it goes till 2700.
Tech Explained: What is Samsung's PQI?
Also at what price are you getting it?
I would suggest you to go to a samsung showroom and check it out before buying.
All the best..
1. Pl. play HD movies on the showroom TV from your pen drive & check out picture quality.
2. Check if you can connect your own smartphone with showroom TV.
3. Check if you can connect your own 3G dongle with showroom TV.
4. Ask for extended warranty details. Samsung offers 1 year standard warranty & additional 1 year warranty on panel.
As it's the newest model it's not available on all retail stores yet they are telling me stock would be available in next few days, it's currently available in only 1 samsung store I would check in other stores in next few days.
prasad1979 said:
All the best..
thanks bro, I would check all these things.
