Planning to Purchase 32 inch LED TV
  • Replies Replies: Replies 53
  • Views Views: Views 6,020
I am using Micromax 50" led which I got for 40k with extended warranty and am fully satisfied with it. Had used Sony and Samsung previously and honestly can't see much difference in all three apart from sound which is a bit low in Micromax for which I have got 2.1 speakers for Rs. 1400/-
Bros why almost all the 32 inch TVs are comming with HD ready pic quality? whereas 22 inch and 40 inch TVs are comes with Full HD quality.
rahul1117kumar said:
What is the difference between hd tv and full hd tv?
HD TV is capable of displaying 720p and 1080i Pixels while Full HD could display upto 1080p :k
Kumar bro, which one is better, also bro if I watch sd channel would there be any difference in watching sd channel in hd or full hd led tv.
Go with Full HD bro(1080p) bro,it is superior to HD Ready/HD TV
No there would be no difference in quality of sd channels between Full HD and HD TV :)
I am planning to purchase a 32 inch led tv, I am little bit confused whether I should go with Sony, Samsung or any other company, kindly suggest me which one is good. thanks
Bro Get a High Quality High Definition Video on Pendrive and Go to Store and play it on Sony and Samsung...
Then you will find which is the best that suits you...
Go for full HD smart TV.
You can watch HD content on HD channels and on youtube also.
Smart TV can provide internet based apps and Wi-fi connectivity in home network.
Though 4k is still far away because of high price of 4k tvs and low availability of 4k content Full HD TV is must these days.
Future of watching TV is in VOD apps like Netflix, Bigflix, Voot, Sony Liv and Jio Play/Jio onDemand.
Wi-fi connectivity is also useful to play content directly from your mobile and PC.
Last week I purchased Sony Bravia W592D full HD smart TV in Rs. 33000/- for my brother. You can consider this model.
i just checked samsung J4100 32 inch led tv
80.1cm (32) HD Flat TV J4100 Series 4 | SAMSUNG India
pls do rate it and review it. thanks
Hi,
The model u selected is good I myself had shortlisted it while i was buying tv last year, but it's actually 2015 series model and now samsung has launched the new K series 2016 like the 80cm (32) HD Flat TV K4000 Series 4 | SAMSUNG India
80cm (32) HD Flat TV K4300 Series 4 | SAMSUNG India
as these are new launch the prices are not shown as of now
And the most important do visit a samsung showroom and compare the quality and features between the J and the K series to get a better idea.
