Good News Bought Onida Fire TV edition 32 inch LED TV. Initial unboxing and setup pics
  • Thread starter Thread starter Esmail
  • Replies Replies: Replies 18
  • Views Views: Views 4,143
Esmail
Senior Editor, OnlyTech
News Columnist
31 Oct 2015
I bought the Onida Fire TV edition smart LED TV which comes with inbuilt Amazon Fire TV. Just finished setting it up, it's very smooth in the operation and navigation through the menus. As soon as I powered it on, it checked for connectivity, I have plugged it in with an ethernet cable instead of wifi and it updated to the latest software version. Setup requires an Amazon account and you can create one if you don't have one already. All major streaming apps are already present so there is nothing major missing apart from Apple Tv+ app if you use that. I decided to go for this instead of the Mi TV4A pro since I prefer the forked android interface of Fire OS over the standard Android Tv OS. Also the remote has dedicated play/pause rewind forward buttons that are missing in the Mi Tv remote. The remote has dedicated hotkeys for Netflix, Amazon Prime video, Zee5 and Sony Liv. The voice control through Alexa is as good as the standard Google assistant.
Congratulations bro.
What's the use of button next to volume keys?
