JioFi 2 Device :How to get better speeds on Jio
  • Thread starter PRK
  • Start date
  • Replies: Replies 5
  • Views: Views 1,020
PRK
31 Mar 2011
Hi, all I have created my 1st video on youtube on how to get Maximum speeds on Jio using JioFi device. (It is for those who are not so tech-savvy, also I have made it as a normal user, no great skills.)
Please try it if you have jiofi device and let me know if it works for you.
I would appreciate if you like the video if it worked for you. Leave a comment if you have any doubts there. Also, share if it worked for you with other jiofi users.
https://youtu.be/hWU54YDmNYg
I don't know if it's okay with posting this post here. But as it is relevant for a lot of users, I posted it here. I hope it helps.
Thanks :tup
RE: How to get better speeds on Jio using JioFi / JioFi 2 device
Here is your video embeded..
Good work bro.. Nice start :clap
Thanks bro
Hi all, did anyone try & found this works?? No comments yet.
