N niyasmkkv Member Joined 11 May 2013 Messages 133 Reaction score 61 25 Oct 2019 #1 My Sony LED Tv which is weirdly started showing popup ads. The fun thing is my TV is not even supports Wifi. Can someone help me how to fix this? I'm attaching pics from my side. [/IMG]
JollyLNB Contributor Joined 5 Oct 2014 Messages 1,227 Reaction score 2,435 25 Oct 2019 #2 niyasmkkv said: My Sony LED Tv which is weirdly started showing popup ads. The fun thing is my TV is not even supports Wifi. Can someone help me how to fix this? I'm attaching pics from my side. [/IMG] Click to expand... That means the TV is in demo mode. https://www.sony.com.sg/electronics/support/articles/00050389 Note: Since I am in Singapore the link is showing as sony.com.sg. There is no difference if you change it to sony.co.in or anything else. Last edited: 25 Oct 2019
iDJ Elite Contributor Joined 23 Aug 2018 Messages 24,743 Solutions 5 Reaction score 30,702 25 Oct 2019 #3 That's not ads bro.
N niyasmkkv Member Joined 11 May 2013 Messages 133 Reaction score 61 25 Oct 2019 #4 DJ Roy said: That's not ads bro. Click to expand... Can you tell me what's it and how to disable it then?
iDJ Elite Contributor Joined 23 Aug 2018 Messages 24,743 Solutions 5 Reaction score 30,702 25 Oct 2019 #5 niyasmkkv said: Can you tell me what's it and how to disable it then? Click to expand... What's your model name and number? Back/Exit/Home button should do it. https://www.sony.co.in/electronics/support/articles/00050389
