My Samsung led 46 inch 3D TV which is 7 1/2 years old got display probelm.
Problem started 3 days back.contacted customer care and service guy visited and told need to change display panel.
it costs 18k-20k. 2 years warranty on new display panel
From Samsung its only option of display replacement, no repairs will be attempted for display for this issue.
when i asked about 2nd route ...A hint, he said try a chance with local technician for repair.but not sure whether it will be fixed or not.
Is it good/safe idea to give TV to local technician...can such problems will be fixed permanently with repair ?? or those are temporary only?
If any one experienced such issue please suggest me which can be good???display panel replacement or repairing with local technician???
Update:
Update:
Problem solved/repaired.Hoping for the best,long service
Back Lit light/LED light Strips are replaced.charged Rs 8,500.(Can be done in 5k-6k in big cities with more technicians availability)
He said out of 8 led strips, 4 are failed. for good long service he changed all 8 led strips.(for the sake of no conflict/ voltage difference between old and new strips)
