How to configure bsnl broadband with huwaei hg630a
  • Thread starter id_866
  • Start date
  • Replies: Replies 18
  • Views: Views 11,541
id_866
13 Dec 2013
My friend used airtel broadband before and he moved to new house now.airtel not available, so he got bsnl connection.how to configure bsnl broadband in huwaei hg630a.called to bsnl customer care no use.bsnl line man have no knowledge on this.thanks in advance
I think it will work.
ADSL router has RJ11 port.
VDSL router has RJ45 Port
main-qimg-1df9c2717146fe11fa69dafad031918b-c
If the airtel one used a phone line in the previous house, then it should work with BSNL..
you just need to reconfigure it with the username and password.
also check if any static IP was set.. it needs to be either changed or removed!
If it has a telephone line input or if BSNL is providing VDSL service, then it'll work. Else not.
