Seeking Help Facing issue in Sony Bravia Led TV
  • Thread starter Thread starter MRizz
  • Replies Replies: Replies 24
  • Views Views: Views 4,188
Status
Not open for further replies.
Guys what is this weird things in my sony bravia led tv.
The led light on the particular area is dead if u take it to Sony centre they will ask you change the panel or some times technician can give u some help without officially knowledge of Sony they can change the particular LED. On other hand if u know any good technician they just replace that particular led alone, but remember that if technician is known person or from your neighbourhood. You can try it will cost u less.
Better let it be like this till there is issue causing major inconvenience as once tv set is opened up there r chances of some or other things getting screwed up while repair work is taken up.
Bro, if it's a small issue , plz leave it. If you have warranty for panel (free) you change it. Otherwise don't. How long it run, you run it. Then you go for a new one.
but my led tv not working .........only red right blinking insted green light on.....................
Bro it's board issue you may have to change the motherboard, it's bit cost less compare to display.
But your snaps show, the star sports running. Ok. If it no work. My opinion Sony center is waste one. You do as kartz Bro said post #11.
my LED TV blinking red light ........only sony logo comming and then tv off and red right blinking 6 times...........plz any help regarding this
I also had this problem tv will turn on then logo comes and after few seconds it will restart itself . So many ants gone inside the tv caused this problem for me. So first check for any ants roaming inside the tv .
Check for any ants roaming inside the tv.
Really. My new Vu TV face it. A small fly enter inside the screen and look like a very small dot. When I saw my heart cracked. Now I take it casual. Anybody eye it. 😜.
Can't understand your post 🙄 are u posting sarcastic comment or what? I'm just telling my experience.
It's not a funny comment, Bro. I still facing in my 55" 4k Vu TV. I am in Shop. So I fixed the diagram. I go home and snapped it and show, Bro. #sorry 50" not 55.
Status
