Picture settings for led tv
ato_tho
4 Sep 2017
Hi just wanted to know whats the best picture settings for led full hd tv. I'm using haier le50b8500. Please share the picture settings if someone is using haier or all the other led tv's.
LG TV you mean?
Yes you can share your picture settings you using. Also is it a full hd tv?
@ato_tho,
Do you keep the sharpness at same level for hd channels too? I have turned mine at 0 for hd viewing and its more natural.
Its TV settings, so all channels sharpness are at same level. So yes.
Just keep on playing with the adjustments unless you feel comfortable , bcos everyone viewing choices are different ..
