Important For PCI Card
Nice information Aakash bro! So you are enjoying 4K in D2H now!! Enjoy!
@Deepu bro: Which software that you are using? You too mentioned that you are getting only the still image from 4K channels.
We both getting 4K channel
But we are using DVB Dream........We are select 4K channel
So Computer CPU Shows 100% and Computer Get Freezing.....
So If WE Install this software It shows Only 68%........Not Freezing and Working Fine
Yes bro. He said, he was getting only still images since CPU is 100%. So, he can also use this software. Not sure if he is using this software.
Akash Modi said:
I am said them and download it and no problem facing
Good! Is it possible to capture video from your PCI card and upload in youtube to share here?
Waiting for the updates from @Deepu bro too..
