Pan India Telecom Spectrum holding chart 2025
Avatar of Esmail Beguwala
By Esmail Beguwala
3 minutes read
1,769 comments
Share article:
Follow us
Pan-India-Telecom-Spectrum-Portfolio-2025
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Sharing agreement with each other so long as both parties hold liberalised spectrum in the same band in the same circle. Spectrum sharing is possible only on a Pan LSA level in block sizes defined by DoT and only after one year of an operator acquiring the spectrum.
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Trading agreement with each other so long as the spectrum being sold is liberalised. Trading of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after two years of an operator acquiring the spectrum.
Share article:
Follow us
Esmail Beguwala
Senior Editor
226 articles published
Related articles
Visit our forums
Comments (1521)Forum replies (248)
Loading new replies...
Reply 4 likes
Reply 3 likes
1,769 thoughts on “Pan India Telecom Spectrum holding chart 2025”
  1. In the spectrum chart, across 900, 2100, 2500 bands for bsnl/mtnl, for several circles, there are many white boxes, mentioning liberalised or non-liberalised but withouth the expiry year mentioned.
    What does this (white box) mean or signify… Not alloted spectrum or any other thing else?
    Reply
    • Spectrum shown in White denotes spectrum which has been reserved for BSNL but hasn’t been allotted yet. When it’s allotted it will be liberalised spectrum.
    • Esmail, your spectrum chart effort & knowlege sharing is commendable & greatly appreciated. Kudos to you.
      My query & curiosity are listed below. Will be grateful if you could kindly share your knowledge of the same.
      Why does BSNL have many major & important circles (like Delhi, Mumbai, Maharashtra, Tamil Nadu etc.) where spectrum in several bands (700, 2100, 2500) has been reserved (white boxes in spectrum chart) but still not alloted? When will these reserved specrum get alloted to BSNL? Do you have any confirmed info of the same?
      Who decides when the allotment is to be made/needed – BSNL or DoT? What is the reason or basis for allotment to few circles only while others have not been alloted?
      Based on all of the above, will the planned 1 lakh 4G sites of BSNL be spreaded across India in all circles or implemented only in few circles, leaving Delhi, Mumbai, Maharashta, Tamil Nadu etc. – where spectrum (700, 2500, bands) has not be alloted yet?
    • Thanks for the appreciation Ashok
      As for the BSNL non allotted reserved spectrum, it’s the decision of DoT as to when, where and how much spectrum is to be allotted for smooth functioning of service.
      As for Mumbai and Delhi, those circles come under MTNL jurisdiction not BSNL so the allotment may have to wait until both telcos are officially merged. As of now they are functionally merged with BSNL handling the operations of MTNL for the next 10 years.
      For the other circles you mentioned like Maharashtra and Tamilnadu, right now BSNL has test spectrum in 700 MHz band which is valid till 30th September so before that expires, sometime this month itself they may be allotted the spectrum in the remaining circles at least in 700 and 2100 MHz bands since the official Pan India 4G rollout date is 15th October.
      As for the 1 lakh 4G BTS target, it seems achievable by March 2025. Before that the 4G rollout will happen but the dense network coverage will happen only after the BTS are live in this quantity.
  2. Esmail Sir, In the spectrum chart…
    1.) For Bsnl/Mtnl, in Mumbai (& Delhi), in 900 band, 5 mhz is shown (in black color) as expired and 1.4 mhz is shown (in whie color) as non-liberalized. Is 1.4 mhz of 900 band being in active use and how much spectrum in 900 band is operational for Bsnl/Mtnl in Mumbai… 1.4mhz or more… Or is there no 900 band spectrum at all?
    2.) For 2500 band, for Bsnl, certain circles are shown in brown color and certain circles in white color (like maharashtra, gujurat, tamil nadu, mumbai etc). Have circles in white color got (alloted) 2500 band spectrum and are they operational?
    3.) Is Vi’s 30mhz spectrum in 2500mhz a continious single block or is it/will it work as Carrier Aggregation (of 20mhz+10mhz)?
    Thanks in advance for your answers.
    Reply
    • 1) 5 MHz of spectrum in 900 MHz band in Mumbai and Delhi had expired in 2019 and has not been officially renewed for MTNL. It will get assigned to BSNL soon along with an additional 1.4 MHz making the bandwidth 6.4 MHz.
      2) only the spectrum shown in brown is allotted to BSNL, the one shown in White is just reserved for them and will be allotted soon.
      3) Yes Vi’s 30 MHz in 2500 MHz band is contiguous but if Vi wants to use it for 4G it will have to be deployed as 20 MHz+10 MHz since the maximum block size for 4G is 20 MHz. Though if vi wants to use it for 5G then it can deploy a continuous block of 30 MHz since the maximum block size for 5G is 100 MHz.
Leave a Comment
