Esmail,
1) When is the spectrum auction expected to be held?
2) whats your guess on when Airtel & Vodafone Idea will increase their tariffs?
3) Whwn will Vodafone Idea integrate completely in Mumbai & Maharashtra?And will they survive at all?
Will be grateful of tou kindly answer thw above questions. Thanks & Regards
1) Between Jan to March 2020
2) Both of them will most probably increase tariffs around Jan 2020 since the AGR issue has left them stripped of liquid cash and they need to replenish it to survive. Also with Jio charging for outgoing IUC now the pricing pressure on them has been lifted which gives them some headroom for a 20% tariff hike for the all in one bundled packs.
3) Integration is going on in full swing, and they are surprisingly ahead of schedule. In Mumbai when I do a network scan I can see only Vodafone 2G/3G/4G network while Idea only has a 2G presence. Vodafone will be predominant in Mumbai whereas idea will be predominant in Maharashtra Circle.
About survival it seems like it can go either way right now with the AGR ruling and the company not having any reserve cash provisioned for it and Vodafone UK having cut all funding to Vodafone India. But they can still monetize their holding in Indus towers or sell off some spectrum to Jio before the auction or by selling bulk data and voice minutes to an MVNO who may want to use its network.
VIL will surely not participate in the upcoming auction as they won’t have the requisite Ernest money to deposit and they are anyway in a state of spectrum surplus.
@esmail here in Chennai VIL integration is going in snail pace. Still both networks are running.
OMG! Great to see you esmail… missed your knowledge & insight a lot 🙂 Request to kindly bring a lot of telecom news & analysis/opinion on this website, so that we can dump TT/Arrogant & Rude Chakri for good!
I will try my best to get a balance between Telecom and DTH news so that Telecom oriented readers are not left disappointed.
