Can Airtel use non-liberalised Spectrum 900mhz,(currently using for 2G service) to reframe into 900 LTE in UP east circle?
They can technically do that but there is no pressing need for them to do so. They will most probably wait for 4 years till the spectrum expires and buy new liberalised spectrum which they will use for 4G.
I think u r right. Overall DoT aslo cleared that reframation or transfer of technology cannot be done in non liberalized or administrative allocated spectrum. The process of technology transfer can only be done in liberalized spectrum.
Airtel should buy additional spectrum in 1800 and 2300 mhz band for extra capacity.
Airtel is eyeing to pick up spectrum on 2300 MHz for existing radios in key cities. 1800 MHz they feel is not needed in the next auction.
More here – https://onlytech.com/airtel-to-bid-selectively-for-spectrum-in-upcoming-auction-with-focus-to-filling-gaps-in-sub-ghz-spectrum/
Can spectrum be bought city wise? I always thought it is circle wise only?
Yes it needs to be bought circle wise only. What Basil meant is that Airtel will pick up 2300 MHz Spectrum only in those circles which have key cities that the operator needs more capacity spectrum for.
