Esmail, the current prices per mhz are for all circles combined right? Like 3297 per MHz in the 700MHz band is for all circles or just one circle? If it’s for all circles, wouldn’t it be much cheaper than the spectrum sold in Germany or South Korea?
Yes the price is for 1 MHz of Pan India Spectrum.
That’s great. So technically, the spectrum is pretty cheap. Hopefully Jio grabs a large chunk in the upcoming auctions!
Do you think Jio’s 5G core is deployed and ready to be used once the auctions are done?
Yes that’s what they are claiming and I would like to believe them because they would like to have the early mover advantage over Airtel.
And Vi is going to get left behind in the 5G race. The operator which once said India isn’t ready for 4G is now itself not ready for 5G.
What is this band plan N77 and N78. Do phone supporting N78 band also supports N77 band plan till 3.8 Ghz
n78 is a subset of n77 band and no it is not necessary that phones supporting n78 should support n77 as well. But considering the device ecosystem present in the market currently, all operators will launch 5G using n78 band only, no one will bother about n77 unless DoT decides to auction spectrum between 3800 and 4200 MHz.
