Total | 26,800.8 | 22,538.1 | 8,030.4 | 1,086 |
@esmail From where can I download pan india all operators spectrum holdings pdf ? I found one on dot site but it was pre 2021 aunction.
No idea bro, if you find it somewhere let me know as well
So from where you prepare the chart above.
I track the auction results and add that to the chart to keep it updated.
Saw you today on Instagram.
Don’t they release these stuffs in public domain.
@esmail
“Jio has already achieved 100% core network availability,” the presentation said. What does it means ?
