@esmail doesn’t spectrums used by ISPs interferes with each other say b3 ?
We use the term ISP for wired broadband operators in general who don’t use spectrum for broadband connections. If u are referring to telecom operators then if 2 operators have spectrum holding within band 3 then both will have their own set of frequencies which will be distinction from each other within the band, so the question of interference doesn’t arise.
Like there is a range of frequencies in downlink and uplink say in b3 and different operators are given spectrum in a small range of that frequency range so that it doesn’t interfere with others ? Am I thinking right
@Ankit kumar suppose in a circle jio has a block of 20Mhz and two blocks of 10Mhz in band 40, considering my phone has no CA then to which block my phone connects ?
That situation won’t arise only, even if the two 10 MHz blocks have been purchased by Jio separately, they are contiguous and Jio will deploy it as a single 20 MHz carrier and not as two 10 MHz carriers. So if your phone doesn’t support carrier aggregation then you will be latched on to either of the 2 blocks of 20 MHz so it won’t make a difference.
