@esmail Don’t you think that 5G scam happening in india ? Smartphone OEMs are giving just one 5G band n78. Some give n77 ⬅️ i think this band won’t be used. N41 only vi owns this. Why don’t they give n40 (op band) and the band which are being used like n5,8,3,1. In future may be n28 be used. Are they doing it intentionally to make profit or they don’t visit onlytech website ? In other countries they give much more bands than required.
Even in the case of 4G, before Jio launched LTE on band 5 you didn’t have any handset which offered band 5 LTE, but once they launched, every manufacturer made sure their device supported it.
So it’s not a scam it’s just smart marketing, by adding n71 the phone is technically classified as 5G compliant because currently no operator has launched 5G on any band, so the layman will opt for the 5G phone instead of going for a 4G phone at the same price point.
Eventually when operators launch 5G then the manufacturers will include those bands in their phones, but more the number of supported bands, higher will be the price of the handset.
Does smartphone OEMs have to pay royalty to SoC makers say Qualcomm to enable more 5G bands ? Also why samsung and Motorola are giving 11-12 5G bands which includes current bands and also popular bands ? Op 9 pro has just 1 or 2 bands of 5G the most expensive phone of op ?
@esmail (1.)Spectrum was administratively allocated to operators in each of the 22 licensed service areas or circles pre 2010, this spectrum is called non-liberalised . DOES IT MEAN THAT OPERATERS WERE GIVEN SPECTRUM FOR FREE ? ALSO WHICH BANDS FALL IN NON LIBERALISED SPECTRUM ?
(2.) Is spectrum in a particular frequency band limited as in B5 it is 17.5Mhz for telecom. Does all country who are using B5 have 17.5Mhz of spectrum ?
(3.) Does as we move towards higher frequency the spectrum (bandwidth) availability increase ?
(4.) What would the spectrum availability in 5G mm waves ?
1) Yes, administratively allotted Spectrum was given bundled along with the license fee and no additional charge was levied for it. Spectrum in bands 3,5,8 were allotted administratively pre 2010. All spectrum in 850 MHz band is now liberalised while some spectrum in the 900 and 1800 MHz bands is still unliberalised and will expire over the next 5 years.
2) No this will differ from country to country, the maximum available bandwidth in band 5 can be up to 25 MHz but in India we have 17.5 MHz available as 2.5 MHz is reserved for the defence and 5 MHz is given to band 8 in the overlapping region.
3) see every GHz has a 1000 MHz in it, whether you consider the low end of the spectrum or higher end. It’s all about how much bandwidth is dedicated to each band. In lower frequency bands ITU has allotted lesser bandwidth whereas in the high frequency bands it has allotted more bandwidth.
4) in millimetre wavelength bands u will have the 26 GHz and 28 GHz bands. I will update the bandwidth for telecom depending upon trai recommendation and what Dot finalises in its 5G auction NIA.
Thank you
