mm-Wave Band | 22000 | 17600 | 5350 | 0 |
Total | 26,800.8 | 22,138.1 | 8,030.4 | 1,086 |
- Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Sharing agreement with each other so long as both parties hold liberalised spectrum in the same band in the same circle. Sharing of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after one year of the spectrum being acquired by an operator.
- Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Trading agreement with each other so long as the spectrum being sold is liberalised. Trading of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after two years of the spectrum being acquired by an operator.
@esmail Does JIO has capped it’s speed because even in village area (Tower only 370m away) at 4 am in the morning i get max 15mbps. Shockingly my phone was connected to band 5 or band 3 but throughout the day it is always connected to band 40. Does jio shut band 40 antenna during these times.
Jio turns off B40 from 2AM to 5AM for power saving
@esmail may you explain difference between contiguous and non contiguous spectrum via a example ?
If an operator holding spectrum in the 1800 MHz band holds a total of 5 MHz but this is held in bits and pieces like 1805-1808, 1810-1812 and 1815-1816 then this is called non contiguous spectrum and it can’t be deployed as a 5 MHz block without intra-band carrier aggregation. On the other hand if the spectrum held by the operator is held as one chunk like 1805-1810 then that can be deployed as a single block of 5 MHz without needing CA so this is called contiguous spectrum.
Thank you
