• Welcome to OnlyTech Forums
    Log in or Register
Suggest A Fiber Broadband Connection.
Jagadeesh
25 May 2016
I'm Living In Coimbatore,Tamil Nadu.I'm Currently Using Airtel Broadband @4 Mbps Speed.Im Looking For A Change In Connection To Some Fiber Providers.I Need Speeds Around 50Mbps And Monthy Rental Around 1000rs.I Need Atleast 25Mbps Speed To The Lowest.Suggest Me A Good Fiber Or ISP Providers.
Bapun Raz
3 Nov 2010
Try railwire broadband. Constant speed. Parallel upload and download speed - both are same speed.
Good service. But maximum speed for TN circle is 20 Mbps by them. They are working on increasing it. Once it is done by April they will update the billing of LCO. You can recharge the new plans then - it is prepaid bb.
Bapun Raz
3 Nov 2010
Go for 10Mbps plan. Better than airtel 4Mbps DSL plan. Also faster than it. It also comes around 1200k with more bandwidth (data). Otherwise check if your area is feasible for airtel vfiber.
Jagadeesh
25 May 2016
Bro..10Mbps Is Available With Tikona for around 650-750..Any Other Provider..?
Bapun Raz
3 Nov 2010
Tikona is not a good and trustable ISP. Please do not go for it because of their price bro. You will regret your decision later.
Ritesh
24 Nov 2014
As said by Bapun bro, never opt for Tikona. Their prices have declined because of downfall of subscribers. Very pathetic service. Few months back i was also did research for tikona and hence, telling you.
Bapun Raz
3 Nov 2010
Even they continue to send bills after disconnection. Which is disgusting, just search for tikona fraud on google and you will find everything about them. They used to spam on our forum with fake id to promote their services, fake user reviews were being posted by those ids.
Jagadeesh
25 May 2016
Thanks Bros..I will Not Opt For Tikona..Wat Abt ACT Fiber..How Is It..? Is It Considerable For [email protected] Fup 25gb And [email protected] Fup 50gb...?I Have Only One Problem Because Of FUP..After Fup I Get only 512kbps Which Is Very Bad..!
Bapun Raz
3 Nov 2010
Act is good and trusted isp.. only bad is their service... its good until its working and you have no downtimes, once issue started it won't be solved easily... you can go for it, value for money speed
Ilikered bro using it... so he can share his experiences with it...
