Got the connection installed on 28th August 2024. ACT has moved to FTTH in my area. The supplied router is a TP Link Archer AX1500 Wifi 6 router. FIber cable is terminated inside my home to a ONU and then cat cable is connected to the router.
Download and upload speeds are pretty good, 350-400+ up and down.
The FUP is 3300GB for me, confirmed this with the customer care and shows on the self care portal as well.
This link also mentions that it is 3300GB which was showing 1500GB before.
Overall the connection has been very stable and the router provided is pretty good. Able to handle 15-20 devices at the same time with no lag or buffer. I was on Airtel FTTH before and their supplied ONT router was trash, had to restart it multiple times in order to get it working properly.
Pings are also great to both domestic and international servers. I am very satisfied with the connection.
Unlimited Data Plans | Terms & Conditions
Enjoy unlimited data plans with fastest broadband speed from ACT Fibernet. Check out the tnc for unlimited broadband plans in chennai
www.actcorp.in
Speedtest by Ookla - The Global Broadband Speed Test
Use Speedtest on all your devices with our free desktop and mobile apps.
www.speedtest.net
