updated indian operator Wikipedia pages with this link as a reference to radio frequency summary
Thank you for the thoughtful gesture 🙂
Hi Esmail,
Most of the 5G devices support band 77 (3300 – 4200). You have mentioned in 3500 MHz as band 41. Is it means those will not work with these devices? Also, Is India going to use 3500 MHz as 77 or 41
As per 3GPP standards, band 52 is 3300-3400 MHz, and band 42 is 3400-3600 MHz and this can be used for 4G LTE just like the lower frequency bands. In India, these bands are being auctioned as bands 52 and 42, if the government intended to have them utilised as bands 77 (3300-4200 MHz) or band 78 (3300-3800 MHz) it would have auctioned it together as a chunk of 300 MHz instead of 2 separate bands.
Though since these are in TDD arrangement and not FDD (uplink and downlink in the same spectrum chunk), the operators are free to use the spectrum in these bands for either 4G as bands 42/52 or 5G as bands 77/78 since the 5G bands cover the entire width of the corresponding 4G bands.
The block size for bands 42/52 is 5/10/15/20 MHz whereas block size for bands 77/78 range from 10 MHz to 100 MHz in multiples of 10.
