@esmail if access spectrum of different blocks like band 3 ,1 can be merged to make a single block, then vil can merge backhaul spectrum also ? Like merging backhaul of Vodafone and backhaul of idea to create one large backhaul ? Kindly reply
Yes, the backhaul spectrum of both operators would also have been merged, though unlike access spectrum which is bought through auction, the backhaul spectrum is allotted administratively. So the DoT allocates additional or takes back excess spectrum depending on the overall userbase of the operator.
@esmail you have also added spectrum which are going to expire in 2021 ? If a operator fails to retain the spectrum means they will loose it immediately or in 2021 only ?
Yes spectrum expiring in 2021 is still shown in the operators holding as well as available to auction column.
If an operator fails to win back spectrum he will lose access to it in 2021 not immediately
Thank you for your reply. I first thought there was enough spectrum available for auction but auction 2020 also includes expiring spectrum. Only 5mhz is available additional in B3, 5,8 😑
