@esmail what about backhaul spectrum ? What frequency is currently used by Jio, Airtel,vil ? And what about e and v bands for backhaul because these bands have potential to replace fiber backhaul ! Awaiting for your reply 🙂
@Esmail: Bro can u list the 21 circles where RJIL has spectrum trading pact with RCOM in 21 circles ? And if possible can u plzz post the Downlink/uplink start and stop frequency for RCOM and Jio’s Band 5 spectrum for Haryana LSA. Inspite of having 10 Mhz spectrum in Band 5 in Haryana Jio has only deployed 5 Mhz in Band 5 in Haryana so I just wanted to check if the blocks are contiguous or not.
The spectrum trading between Rcom and RJio in Band 5 was in 13 circles whereas the spectrum sharing agreement between the two telcos was originally in 21 circles (All except Jammu and Kashmir circle) but when Rcom’s license in Gujarat expired 2016 the spectrum sharing agreement for that circle also ended. So currently the Band 5 spectrum sharing agreement between Rcom and RJio is active in 20 circles, which will be down to 9 circles by next year when Rcom’s license expires in 11 more circles where it has no other spectrum that it has bought in an auction. For Haryana circle out of the 5 MHz shared from Rcom, 3.75 MHz is set to expire next year so hopefully, Jio will just buy a chunk of 5 or 10 MHz in the upcoming auction and then deploy it together in Haryana.
