Hey Esmail, good to see you here. Is there any date finalised for the auctions?
It will be held sometime between January and March 2020. As of now there is no exact date finalised.
@Esmail Just Saw that 3500 MHz can be used for LTE also. Is it possible for operator to deploy this band as LTE in a very dense area like colleges and later move to 5G
The device ecosystem for Band 42 LTE is not mature as of yet, but that has been the case even with bands 40 and 41 in the past and once telcos buy this spectrum, manufacturers will incorporate support for it in upcoming devices. In theory, it is possible to use this spectrum for 4G in the near term and then refarm it for 5G in the long run.
