@Esmail –
One odd thing I noticed in Airtel’s 5G network in n78 in UPW was in some places it has deployed just 60 MHz instead of 100 MHz. Any idea why that’s the case?
Second question – What is Jio doing with the remaining 30 MHz of n78 wherever it bought 130 MHz? FWA perhaps?
