Hey Esmail. Hope you’re doing well. I have been following your work since the old days. Thank you for putting in so much hard work in this!
I have a few questions:
1. BSNL is in the process of installing 100000 4G sites, which are also upgradable to 5G. Are all of these greenfield sites or include brownfield ones as well? Or they are installing 100000 greenfield sites plus some brownfield ones as well? I have seen both types.
2. GoI recently announced that 320 MHz of spectrum can be released immediately, meaning the bands have been identified and frequencies have been earmarked. Any clue which bands are these?
Ure welcome 🤗
1) As per what I can reckon these 1 lakh sites include both new greenfield as well as upgradation of existing BTS with new 4G antennas (brown field) deployment. The new antennas will be enabled for 5G use through a software switch in the future when BSNL rolls out 5G service.
2) The DoT has realised that telcos need at least 2000 MHz of spectrum in the mid band between 1 to 6 GHz range. Out of this currently only 900 MHz is available in every circle so they have identified 687 MHz more which can be freed up (in various bands in this range, band wise break up was not revealed). Out of this 687 MHz only 320 MHz can be released immediately and the remaining can be released by next year end and in 2029. Still another 313 MHz will be falling short and they are trying to figure out where to get that from.
Sir, what is the reason for Airtel still having some 850mhz band spectrum in few circles even when its not using it actively in any of the circle? Will Airtel implement 850mhz band anytime soon in the future. If not whats the purpose of hoarding such spectrum?
Also, are the 850mhz band spectrum in the name of Rcom being actively used by Jio or anyone else?
Airtel bought 850 MHz in circles where it was cheaper than 900 MHz or where 900 MHz wasn’t available.
They intend to use it for indoor coverage for 4G since VoLTE needs low frequency spectrum to avoid call drops. In the future if they get enough 900 MHz spectrum they may consider selling it to Jio even.
Rcom’s 850 MHz spectrum is being used by Rcom itself for its enterprise segment users. If you see the TRAI subscription reports released every month, you can notice Rcom still reports it’s subscriber figures to TRAI even though it has shut commercial operations.
