@Esmail, thanks for the response. If the total bandwidth of 700 mhz band is 45mhz, then how much is the total bandwidth of 900 mhz & 850 mhz bands?… is it also 45 mhz or around that, with 20 mhz for telcos and rest for Govt/Defence use….can you kindly provide the break up if any? Thanks once again.
@Esmail. Recently, here was news that Indian Railways will be allocated ADDITIONAL 5mhz in 700 band, over and above the already allocated.
Since all the 25 MHz bandwidth of 700 MHz band are assigned and in use, where will this additional 5 MHz come from ?
Is the Government planning to release another 5 MHz of this band for licencing ? Or are they planning to snatch 5 MHz from BSNL and allocate it to Indian Railways?
No, the total bandwidth of 700 MHz band is 45 MHz of which 10 MHz is allocated to Ministry of Defence, 5 MHz to Railway, 5 MHz to Metro networks. Out of the remaining 25 MHz, 10 MHz was bought by Jio and 10 MHz was allocated to BSNL and now only 5 MHz was remaining. Jio asked DoT to not allocate this last block to the railway and to let it remain available for future demand of telcos. It offered to set up the private network for railways using it’s own spectrum holding by providing dedicated bandwidth like they do for other enterprise users.
But trai has recommended Dot to just allot the last block to railways. If this happens then there will be no spectrum left in this band for future auctions.
