Pan India Telecom Spectrum holding chart 2025
Avatar of Esmail Beguwala
By Esmail Beguwala
3 minutes read
1,769 comments
Share article:
Follow us
Pan-India-Telecom-Spectrum-Portfolio-2025
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Sharing agreement with each other so long as both parties hold liberalised spectrum in the same band in the same circle. Spectrum sharing is possible only on a Pan LSA level in block sizes defined by DoT and only after one year of an operator acquiring the spectrum.
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Trading agreement with each other so long as the spectrum being sold is liberalised. Trading of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after two years of an operator acquiring the spectrum.
Share article:
Follow us
Esmail Beguwala
Senior Editor
226 articles published
Related articles
Visit our forums
Comments (1521)Forum replies (248)
Loading new replies...
Reply 4 likes
Reply 3 likes
1,769 thoughts on “Pan India Telecom Spectrum holding chart 2025”
  1. 1.) Is the 20mhz 2100 band lying with IAF active & operational by them? Is it possible that the 20mhz 2100 band spectrum of IAF is exchanged with Bsnl 10mhz 2100 band spectrum, as Bsnl will need more spectrum for its growth?
    2.) Any idea on how is the ecosystem & real world performance of 2500 band for 5G when compared to 3500 band?
    3.) Whats the total spectrum availability of 2500 band… including those not auctioned/lying with other govt orgs incd defence which van be released in furure for auctions.
    Reply
    • 1) Yes the spectrum is in use and is even visible as MCC MNC code 404 999 in various parts of the country where the defence forces have their bases. We can’t expect the ministry of defence (MoD) to give up all the spectrum that they hold since they also need it for their communication purposes.
      2) 2500 MHz has been traditionally used for 4G LTE but if it were to be deployed for 5G then it would provide a better coverage than the 3.5 GHz band and the data carrying capacity would be almost at par when the same bandwidth of spectrum is considered.
      3) The total bandwidth of the 2500 MHz band (B41-n41) is 194 MHz of which DoT has 60 MHz and the remaining is with Department of Space (DoS). Yes we can expect more spectrum to get freed up for commercial telecom usage, since the DoS recently freed up 20 MHz which increased DoT’s holding from 40 to 60 MHz in this band.
  2. 5G service is not available in my area. Has the implementation process of Jio’s 5G services slowed down? My area is located near the state highway (UP East). Jio tower is also there. But only 4G service. Any idea?
    Reply
    • Arjun, dont expect any reply or response form Esmail. He doesnt care to respond to users queries… several unaddressed & pending queries prove the same. Dont know the reason though. I also wanted to ask questions, but did not ask knowing that it wont be answered.
    • Hey Girish, sorry for the delayed responses. I haven’t checked the comments section here in the past one month. There hasn’t been any new development in the spectrum holding of operators lately and I wasn’t expecting as many queries regarding the same.
      But I will make it a point to check it regularly from now on and respond promptly. Please feel free to ask me your questions 🙂
      Readers may also feel free to post their doubts on relevant discussion threads on our community forums, where other members may also respond to them in a timely manner.
    • Yes, Jio has completed its 5G rollout targets Pan India and new rollout has been put on the slow track for now, so as to reduce the capital expenditure.
      Usually along state highways you can expect 4G coverage only, since there aren’t many use cases for 5G which is more beneficial in densely populated urban and semi urban clusters.
Leave a Comment
