Esmail Sahab, What is the reason for BSNL 4G having worst latemcy and pings (resulting in websites & apps failing to load sometimes)? Is it due to poor core network capacity or backhaul capacity or web servers capacity or anything else, or a combination of all thes?
It’s a combination of all of those. Hopefully Tejas and Tata will change that to some extent.
Is the 20mhz 2100 band lying with IAF active & operational by them? Dont think IAF alone will require that much of spectrum for their operations.
Hence, is it possible that the 20mhz 2100 band spectrum of IAF is exchanged with Bsnl 10mhz 2100 band spextrum, as a commercial company Bsnl will need more spectrum for its growth.
By the way, when is the additional 5mhz 2100 band & 10mhz 700 band reserved spectrum for Bsnl getting finally alloted by DoT pan India?
