Jio 5G vendors:
Ericsson – Madhya Pradesh, Rajasthan, UP (West), Himachal Pradesh, Jammu & Kashmir
Nokia – Karnataka, Kerala, North East
Any idea about up east ?
Airtel vendor information pan india:
Ericsson – Rajasthan, Haryana, Delhi NCR, UP (West), Himachal Pradesh, Jammu and Kashmir, Assam, North East, Andhra Pradesh, Tamil Nadu, Karnataka
Nokia – Mumbai, Gujarat, Madhya Pradesh, UP (East), Bihar, West Bengal, Odisha, Maharashtra, Kerala
Samsung – Kolkata, Punjab
