@esmail What is your view for n71 600mhz ?
Not n71 that’s the band plan for America, whereas for India we will implement 600 MHz as n105 as per Asia Pacific telecommunity. Just like 700 MHz in India is implemented as n28 not as n12/13/14 in America.
Also the device ecosystem in 600 MHz hasn’t developed which is why the demand from telcos is low, and it wasn’t put up for auction this time.
Ideally DoT should move Railway and Defence allotment to this band and free up n28 for the telecom sector, since the Railway and Defence communication infrastructure will be built from scratch and can be indigenously customised by TCS and Jio using their in house stack while the commercial 5G deployments can be accelerated in the well established n28 with good device market penetration.
DOT has not release 40 mhz in sub ghz band, 199 mhz in mid band and 130 mhz in c band plus defence and railway reserve.
DOT should not introduce any new band and released completely spectrum in current band.
In bihar circle, band 41 has 0 MHz left unsold
Thanks for pointing out the error, it has been rectified. I had forgotten to remove it from unsold after adding it to Vi holding.
Hey @esmail otherthan indus tower and American tower cooperation is there any other company for tower sharing.
Indus is the only major provider (2nd largest in India) with shared tenancy catering to Airtel and Vi. Apart from them you have smaller players like Tower vision, GTL infrastructure, HFCL Ltd. With insignificant market share.
As for American tower corp it was acquired by Brookfield Infrastructure (now the largest tower company in India) earlier this year who had also bought bought Reliance Jio Infratel 4 years back has a single tenancy agreement with Jio for 30 years.
BSNL has its own tower portfolio which is used by it and MTNL.
So 30 year single tendency agreement will be applicable for ATC Infra which is acquired by Brookfield or not?
I don’t know the exact contours of the deal. The ATC towers may or may not be a part of the exclusive deal between Jio and Brookfield but the dues owed by Vi for it’s usage prior to the acquisition by Brookfield will be receivable by ATC parent company only, that was clarified in the acquisition deal.
