Hi Esmail, any clue if 10 MHz spectrum in B3 has been formally allocated to BSNL in Delhi circle?
Also, BSNL has been allotted a new MCC-MNC for Delhi: 404-39 specially for 4G/5G services.
Not as far as I’m aware. It’s not even updated on Saral Sanchar yet. It’s reserved for BSNL but awaiting formal allotment.
Thanks for updating this Article Esmail Beguwala. But I am not able to scroll beyond sub-GHz in mobile mode and beyond 2.1 GHz in desktop mode. I wanted to see spectrum holding of n40, n41, n78 etc.
It will be better if low band, mid band and high band details are one below the other of spectrum holding worksheet.
Thanks for bringing this to my attention. We have been able to fix the issue and you will now be able to find the right and left arrow keys at the footer bar to load the previously inaccessible pages. Let me know if there is anything else.
