Total | 26,800.8 | 22,538.1 | 8,030.4 | 1,086 |
thanks @Esmail for giving this info
@Esmail
As i seen in the above spectrum chart. jio has aquired 20mhz in 1800(band 3) up east circle. but it has developed only 10 mhz in band 3. why..any logic behind it? even in many circles it had already deployed 20mhz in 1800.
The only case where such a situation would arise is if the spectrum held by the operator is not contiguous and the operator is forced to deploy it in 2 blocks of 10 MHz each instead of a single 20 MHz block. Maybe if DOT harmonises the spectrum holding of all operators in the band to make it contiguous before the next auction, then Jio may be able to deploy it as a single block.
