Only Jio and Airtel are using spectrum effectively.
Vi, Adani and BSNL are just holding on to this resource and paying for it but not earning anything in return.
Hi Esmail, Im a BSNL WB user staying in Mumbai, and my connection latches on to MTNL Mumbai network. But at most places in Mumbai the network automatically latches on to 2G 1800mhz DCS network and though it shows full signal it also shows emergency calls and people are unable to connect with me…am unable to receive or make calls. Also at most places, there is no 3G network.
Can you please help me understand the why this is happening. What is 1800mhz DCS network? And MTNL and BSNL are supposed to have 900mhz band…why is that not seen on MTNL Mumbai network?
Thanks in advance for the help.
Im also a Bsnl Maharashtra user in Mumbai and am facing the exact same issue. Esmail, can you please explain what is 1800 DCS network, and why is MTNL Mumbai showing emergency calls inspite of full signal in 2G?
I do not have complete knowledge about this issue since neither I nor anyone I know uses MTNL network in Mumbai since the network is totally messed up and there is better service availability from Jio, Airtel and Vi at the same or even lower tariffs.
As for the 1800 MHz spectrum we don’t have any official word from DOT about MTNL having access to any spectrum in this band in Mumbai, they have only 900 MHz for 2G. But since their license has already expired and not renewed due to operations being in the process of getting merged with BSNL we don’t know if internally the government has signed an intra circle roaming agreement ICRA with one of the private operators to let the MTNL and roaming BSNL users to use their network while in Mumbai which may lead to the emergency calls message to be displayed.
Maybe once MTNL and BSNL operations are fully merged we may get more clarity on this.
