For VI – now only 8 circles are there where the base tariff is not hiked yet to 99 for 15 days and still gives 28 days validity and 279 giving 90 days validity as on 26 th August 2023
These 8 circles are – Karnataka, Rajasthan, Assam, Odisha, J&K, NE, HP and Bihar
In Haryana only the 99 plan is removed completely and in other 13 circles the 99 plan validity reduced to 15 days
VI increase base tariff in Delhi and Gujarat
Now Mumbai, Gujarat and Delhi has base plan 99 rs for 15 days
also haryana
kerala also
In Kolkata also vi increase tariff
maharashtra and goa also
