@Esmail thanks for sheet update.
Please tell how airtel & Vi uses same spectrum for 2G & 4G if the BW is just 5 MHz?
I didn’t get your question exactly, if it’s about a particular band and specific circle please mention it.
If it’s a general question then the only way an operator can use a 5Mhz block for both 2G and 4G simultaneously is if they go for narrow band deployment of 3 MHz on 4G and remaining 2 MHz for 2G.
Or they can have that 5 MHz block being used for 4G on cell sites in one part of the circle and for 2G on cell sites in another part of the circle.
On the other hand if you ask about same spectrum block being used for 4G and 5G then that can easily be done through dynamic spectrum sharing (DSS) technology where the cell sites can decide whether to use the spectrum for 4G or 5G depending on the devices connected to the tower at any given time. If more 4G devices are connected then most of it will be used for 4G and if more 5G capable devices are connected then most of it will be used for 5G.
Wow thanks for the information,
Yes I wanted to know the generally but how can It shows for example:-
In Delhi NCR – 5Mhz of 900 band used for 2G & 4G but in 4G it shows full 5MHz instead of 3 MHz narrow band?
In a 2G/4G scenario it can be only like this 3Mhz for 4G & 2Mhz for 2G if used on a same bandwidth at same location for both networks?
In the example you have given it is likely that the entire 5 MHz in the 900 MHz band is being used for 4G only and the 2G operations are shifted to the 1800 MHz band.
Hi, Esmail sorry for incorrect message.
I wanted to say like in Delhi Circle AIRTEL has 2G & 4G on 900 MHz and still 4G shows full 5Mhz BW.
*Delhi NCR Vi 2G works on 1800 Band along with 4G & it shows 10Mhz but Airtel uses 900 for 2G/4G both on 5Mhz BW
Airtel LTE vendors in Punjab and Haryana circles ?
Nokia
ZTE circles ?
Yes
Ericsson for Haryana Circle (Earlier it was ZTE).
Punjab – ZTE/Nokia LTE being swapped to Samsung for 5G. Haryana ZTE to Ericsson for 5G
I think 4G LTE will also be swapped to Ericsson for Haryana circle since Airtel is deploying 5G NSA and 5G NSA requires same vendors for both 4G and 5G. Similarly, I think for Punjab circle 4G will be swapped to Samsung along with 5G deployment by Samsung.
