Why Airtel still not launched 5g in Kolkata yet
Airtel 4G vendor for Kolkata circle is ZTE which is now being swapped to Samsung. That’s why taking time.
Now that Airtel has launched 5G in Kolkata, how is the speed and latency ?
@Ankit kumar: Has Jio deployed 20 mhz in 1800 mhz frequency band (Band 3) in Gujarat and Odisha ?
Yes
@Ankit Kumar: Brother but you did not upload any video regarding the upgrade. Please make a video regarding that on your channel.
