Pan India Telecom Spectrum holding chart 2024
Avatar of Esmail Beguwala
By Esmail Beguwala
3 minutes read
1,708 comments
Share article:
Follow us
Pan India Telecom Spectrum Portfolio 2024
Decimal values are rounded off to the nearest whole number for ease of representation.
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Sharing agreement with each other so long as both parties hold liberalised spectrum in the same band in the same circle. Sharing of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after one year of the spectrum being acquired by an operator.
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Trading agreement with each other so long as the spectrum being sold is liberalised. Trading of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after two years of the spectrum being acquired by an operator.
Share article:
Follow us
Esmail Beguwala
Senior Editor
226 articles published
Related articles
Visit our forums
Comments (1482)Forum replies (226)
Loading new replies...
Reply 4 Likes
Reply 3 Likes
1,708 thoughts on “Pan India Telecom Spectrum holding chart 2024”
  1. Hi Esmail, did exactly as you said… changrd the dns server to cloudfare (even tried google dns)… but the same exact problem persists…. of webpages and apps not some times times not loading… even during very late nights or early mornings… when there is the least traffic.
    All i want to know & understand is what or where the problem lies… as to why many times webpages or apps dont load at all while using 4g internet regularly (both on mobile & laptop) but the same webpages or apps load properly while using through a VPN, in the exact same internet session (without switching off or on the internet)!
    Esmail, please help & guide, as to where the problem lies?
    Reply
    • I can’t zero down upon where the issue lies. Like I suggested, create a thread on our community forum and put your query there, someone who has faced the same issue might be able to help.
  2. Esmail, big fan of yours since early TT days. Need a big help from you. Please help me. I shall be eternally grateful to you for your help.
    I’m from Tamil Nadu and use BSNL 4G internet, always on my mobile only. The problem is that with BSNL 4G, webpages or apps don’t load at all, many times and on daily basis, whether its day time or very late nights. But when using it through VPN, it loads/works fine. Additionally, there is huge latency, ping and packet loss many times, even when it works/loads.
    Can you kindly help me understand as to why and where the problem is, and why webpages or apps don’t load usually on BSNL 4G but work fine when using VPN, when used at the exaact same time/session?
    With whatever little understandi I believe this is not an issue just with only the site/bts. Is the problem bigger, due to BSNL’s DNS server or Core Network capacity or anything else? Will be grateful if you can explain in detail.
    Thanks once again. Grateful to you.
    Reply
    • Instead of VPN did you try using a public DNS as an alternative to BSNL own DNS? If your phone is running on Android version higher than 9.0 then u can find the private DNS option under the network and internet settings and in that set the host name as 1dot1dot1dot1.cloudflare-dns.com and save it. If it’s a DNS issue from BSNL side, this should resolve it.
      Also you can head over to our OnlyTech forums section and create a help seeking thread and other forum members who have faced a similar issue with BSNL in Tamil Nadu might be able to help you out with a solution that worked for them.
      Happy to have you with us here on OnlyTech 🙂
Leave a Comment
