Sir, kindly help. Struggling for a solution with my telco since a long time. Your guidance will help me a lot in dealing with them.
1 – How many max sectors can be added in a 4G BTS & also 5G BTS?
2 – Are core networks of telcos city, level or state level or national level or all.
3 – What causes high latency & jitters in 4G network. Is it congestion at bts level or core network level or both.
4 – When there are constantly conflicting sites/bts (home exactly in inter-junction of 2 sites), then what could be the best possible solution – change sector angle or sgnal strength or both of dominating bts, or anything else.
Happy birthday 🎂 @esmail sir
Thank you ☺️
@Esmail, Wishing you a very Happy & blessed Birthday. You are a blessing to many, for without you, our knowledge of telecom would be incomplete/limited. Your knowledge & sharing has immensely helped many of us. Thanks for your efforts & stay blessed forver.
