Pan India Telecom Spectrum holding chart 2025
Avatar of Esmail Beguwala
By Esmail Beguwala
3 minutes read
1,769 comments
Share article:
Follow us
Pan-India-Telecom-Spectrum-Portfolio-2025
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Sharing agreement with each other so long as both parties hold liberalised spectrum in the same band in the same circle. Spectrum sharing is possible only on a Pan LSA level in block sizes defined by DoT and only after one year of an operator acquiring the spectrum.
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Trading agreement with each other so long as the spectrum being sold is liberalised. Trading of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after two years of an operator acquiring the spectrum.
Share article:
Follow us
Esmail Beguwala
Senior Editor
226 articles published
Related articles
Visit our forums
Comments (1521)Forum replies (248)
Loading new replies...
Reply 4 likes
Reply 3 likes
1,769 thoughts on “Pan India Telecom Spectrum holding chart 2025”
  1. Esmail, is Vi using different type & quality of codec for VOLTE when compared to Jio? Because Jio VOLTE sounds a lot clearer n louder than Vi VOLTE, on the same handset.
    And why is Vi not implementing VOLTE across all its circles, in spite of VOLTE being efficient (cell breathing as you have explained) and significantly cheaper to operate & maintain?
    Reply
    • I’m not sure about the codec being used by Vi for VoLTE. But they will not be enabling it on all towers anytime soon, they have their 2G network to use as a fallback for voice service and they will use that to its maximum potential.
  2. @esmail, what is APT in 600mhz band alloted to BSNL? Is it widely used world over by global telcos? And how different or better or worse is it when compared to 700mhz N78? What 5G band (N?) is APT 600mhz in India?
    Reply
    • APT 600 is a new frequency band plan in the 600 MHz range proposed by Asia Pacific Telecommunity. It is yet to be regularised by International Telecommunication Union, that’s why there is no band number. And since there is no band number, 3GPP has not included it in any of the releases. Consequently, there is no device on earth that supports this band.
      The other band plan in the same frequency range is Band 71/n71, which are used in US and Canada extensively.
      Why the government hastily allotted 10 MHz of APT 600 band plan to BSNL is best known to them. Now, even if TCS-Tejas-CDoT consortium successfully manufactures radios that supports APT 600, it will be commercially unviable since there is no device available in the market, let alone device ecosystem. Instead 10 MHz of n28 should have been allotted to BSNL.
Leave a Comment
