Is the c band 3500mhz N78 & 700mhz N28 5G bands TDD or FDD?
In the spectrum chart, there is no mention & details of 600mhz band alloted to BSNL. Can you kindly add that.
n78 and n28 are TDD and FDD respectively.
With regards to the first part of your comment, Abhilash has already answered it.
With regards to the second question, 600 MHz spectrum is not yet allotted to BSNL it is only reserved for them, which is duly shown in the spectrum chart, you can scroll to the end to the chart and check on the last sheet beyond the mm-wave band. Once Dot officially allots the spectrum to BSNL I will shift that sheet to the front, ahead of the 700 MHz one.
Esmail Sir, what could be the reason for very poor pings (high latency) of 150-250ms for Vi 4G in India, when compared to 40-50ms of that of Jio & Airtel 5G?
And why has Vi not implemented even basics like VoLTE on all its sites & circles? Why does its customers require to manually activate it via customer care instead of automatic like with Jio, Airtel etc.
Also, read somewhere (comment on TT) that Vi is using a different codec for its VoLTE and therefore is having interportability issues (doesnt work) with other telcos? Is this correct?
My parents have idea sim in BH circle and VoLTE icon is shown in the phone but not on Vodafone or vi sim. Also unlike jio and Airtel which shows HD in Google dialer while calling but not in idea.
