@esmail what is LAA in LTE ?
Licensed-Assisted Access (LAA) is a key milestone on the road to 5G, delivering speeds of above 1 Gbps. LAA is an LTE feature that leverages the free 5 GHz unlicensed band in combination with licensed spectrum to deliver a performance boost for mobile users.
Any practical use in India.
It is useful but not for our telcos as that tech is to provide 500-600Mbps speeds over LTE using 4/5CA but our networks are not focused on providing such speeds they just want capacity and cap data speeds to 100/200Mbps max
Do you watch Ankit Kumar speedtest videos ? I have seen screenshots of above 500mbps down in Airtel
It’s Test sim with better speed cap and that results on controlled site in proper conditions not everyone can achieve that
But it means that they(Airtel) is capable of delivering such high speeds.BTW which circle do you belong to ?
They’re capable of giving such speeds in some circles and selected towers only. But 200Mbps they can give in many circles.
I’m from Chennai Circle here Airtel capable of 150Mbps only in my city
Many telcos like JIO, Airtel, Vi etc. are switching off certain bands (2300, 2100) on certain low load bts (as per their network people) from 2am to 6am claiming for power saving. This is leading to poor network coverage.
How much power appx is saved by switching off just one band (2300/2100) for just 4hrs on one tower?
Is this so called power saving policy of telcos legally allowed? Why are the Govt & regulators like TRAI, DOT not doing anything to stop this?
It is up to the telco as to what they wish to do for power saving. If they want to lower the emission power or switch off certain bands at night they cant be penalised for it. TRAI wouldn’t intervene unless they are doing a complete network blackout leaving consumers with no network at all.
I think Airtel only shuts b40 at night from when I don’t know but till 7AM.
