Pan India Telecom Spectrum holding chart 2025
Avatar of Esmail Beguwala
By Esmail Beguwala
3 minutes read
1,769 comments
Share article:
Follow us
Pan-India-Telecom-Spectrum-Portfolio-2025
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Sharing agreement with each other so long as both parties hold liberalised spectrum in the same band in the same circle. Spectrum sharing is possible only on a Pan LSA level in block sizes defined by DoT and only after one year of an operator acquiring the spectrum.
  • Telecom operators holding CMTS/UASL/UL licenses can enter into a Spectrum-Trading agreement with each other so long as the spectrum being sold is liberalised. Trading of spectrum is possible only on a Pan LSA level in block sizes defined by DoT and only after two years of an operator acquiring the spectrum.
Share article:
Follow us
Esmail Beguwala
Senior Editor
226 articles published
Related articles
Visit our forums
Comments (1521)Forum replies (248)
Loading new replies...
Reply 4 likes
Reply 3 likes
1,769 thoughts on “Pan India Telecom Spectrum holding chart 2025”
  1. @esmail will BSNL only get additional 5 Mhz in b1 expect Delhi (10 Mhz b3) and RJ (5 Mhz b5) for 4G services ? Also what about b41 holdings , will that also be used for 4G ? Last query if BSNL only launch 4G on b1 and b41🤞🏽 how will they manage good coverage ?
    Reply
    • I try to refrain from commenting much about BSNL since it’s very unpredictable, the government reserves spectrum for them but doesn’t assign it. And when they do it’s not clear whether they will hold it for long or surrender it for a refund or ask for a free extension. So coming to your last query yes even if they launch 4G on 5 MHz block of band 1 and 20 MHz block of band 41 it will still give better speeds than their 3G network and yes it will be sufficient since it is a network used only by ppl living in remote areas which are not served by Jio and Airtel. It’s not like they are competing head on with the two giants, since no person with a sound mind would opt for BSNL 4G if he/she has Jio or Airtel 4G coverage in their area, so the load on the network won’t be an issue.
    • They have not assigned but still BSNL in Andhra is using two 5MHz B1 blocks for 3G and 4G and in one place they have 10MHz B1 deployed for LTE too just checked on last Sunday. I can share pics with EARFCN and frequency details too
    • Everything is allowed for BSNL, if a private operator were to be found using spectrum that wasn’t allotted to them by DoT, they would have had to pay hefty fines, but if BSNL does it it’s okay. Even the 900 MHz that it is currently using for 2G services had expired 2 years back in 2020 and in the latest spectrum holding disclosure by DoT before the auction it said that the government is still in the process of considering the re-allocation of the 900 MHz spectrum to BSNL which means they have been using it for free since the last 3 years. That is why I have shown the holding in white rather than assigning it a colour denoting expiry.
    • Anything about RCom resolution?
      Yesterday something happened. RIL subsidiary has agreed to takeover Anil Ambani assets as ETTelecom.
    • Those are passive infrastructure things like towers and fiber, not active infrastructure like spectrum holdings.
  2. Esmail Sir, Big fan of yours. Learnt so many things by just reading your comments/replies. I have a very important query. Will be grateful if you could kindly answer that. Thanks in advance.
    When the smartphone or feature phone is lying idle (not using any internet, calls or sms) but when latched to the network (2G/3G/4G), does the phone actively use any spectrum or other resources of the telcos (Airtel, Jio etc.)? And is it same for all technologies – 2G, 3G, 4G (esp 4G/VoLTE) or is it different for each? Simply put, does it cost telcos anything even if a customer is not actively using the connection and is lying just idle in the phone without any usage (esp in 4G/VoLTE)?
    Reply
    • Good question Shamit, I’ll try and explain it in simple words to make it easy to understand.
      As far as the data component is concerned, a phone connected to the network but in standby mode does not consume any data bandwidth actively unless there is some background task running and mobile data is turned on, in which case few data packets may be uplinked or downlinked occassionally.
      As far as the voice component is concerned even though there is no direct consumption of the operator’s network resources, a phone in standby mode connected to network still counts as an active connection to the tower or cell-site serving a particular area. To understand the implication this has on 2G and 3G network, you need to understand the concept of cell-breathing in self optimising networks (SON). This is a dynamic load balancing technology, whereby a cell site when connected to too many devices, reduces it’s emitting power thus reducing its coverage radius so that instead of giving substandard service to all devices it delivers quality service to devices closer to the tower while offloading devices further away from the tower to let them get served by another cell site that is lesser congested.
      Now if you consider a phone of an inactive subscriber who doesn’t recharge his connection but just keeps the sim idle in a feature phone or smartphone which is switched on and connected to the network and he is close by to a cell tower, and another phone which is of an active connection but is very far from the tower, the active connection phone may not be able to make or receive calls since inactive connections which are closer to the tower are adding to the congestion and overloading the tower. This is why Airtel and Vi keep cleaning up inactive numbers from their network.
      This cell-breathing does not effect LTE/VoLTE networks, which is why for a very long time Jio was not bothering with deactivating inactive numbers. Now you may wonder why then did they recently start deactivating these numbers? The answer to that lies in the average revenue per user (ARPU) figures. Inactive numbers don’t contribute to revenue and end up diluting the ARPU which reflects baldy on a telco’s balance sheet, which is why to improve the ARPU Jio cleaned up the inactive numbers.
Leave a Comment
