@Esmail, just out of curiosity can you please tell what is the spectrum in between 1k Mhz to 1.7 Mhz being used for?
*1000 MHz – 1700 MHz
According to the national frequency allocation plan 2018, all frequency between 600 to 1800 MHz is allocated for mobile communication purposes. We might see some band like 1400 MHz being opened up for telecom in the future.
@Esmail Bro why did Band 8 spectrum in some circles like Kolkata get reduced?
Ideally the increased spectrum availability was resulting from spectrum being released by the defence and railway and DoT was supposed to put it up for sale. But for some reason they are not putting it to auction. Maybe next year they may.
