@Esmail Beguwala In 2021 Auctions we had 30MHz in 700MHz band.Where did the 5Mhz block gone?.Now only 25MHz remaining.
Good question, even I have the same question in mind but only DoT can say what happened to it.
The NIA only mentions spectrum has been reserved for BSNL in 600 MHz, 3300 MHz and 26 GHz bands and doesn’t mention anything about the 700 MHz band.
But if you see the sub GHz spectrum cap DoT has calculated considering 700 MHz bandwidth as 25 MHz only not 30 MHz. So according to the new spectrum cap rules, spectrum reserved for BSNL in those 3 bands is not accounted when calculating the caps but as far as 700 MHz goes that’s not an exception.
And any spectrum which had been put up for auction but remained unsold in previous auctions needs to be accounted for when calculating the cap.
Which leaves one remote possibility that Dot may have given the Railways an additional 5 MHz block as their initial demand was for 10 MHz and Dot had given them only 5 MHz.
Only way we can get a clarification is if one of the operators asks this question to Dot and Dot replies in the clarification release next week. Even if you file an RTI for DoT they won’t divulge the info to a non stakeholder.
Don’t you think it’s waste of resources when DoT has kept 600Mhz for BSNL when there is no ecosystem and when there is no development of 4G PAN India when they have liberised spectrum in band 8 since 2020?
How much is reserved for BSNL in 3300Mhz and mmWave?
Yes, that is why BSNL has asked DoT to give it 70 MHz instead of 6oo MHz.
40 MHz in 3300 and 400 MHz in mm wave.
It’s all already updated in the chart.
Is total spectrum in n78 per circle is 330 or 370 MHz ?
Total is 370 MHz, out of which 40 MHz is reserved for BSNL and 330 MHz is available for the private operators.
@esmail has the validity of spectrum given to BSNL reduced to 2042 ? You had earlier mentioned it 2052 ? As the validity has been increased to 30 yrs can we expect 1.5x increase in spectrum price in upcoming auction ?
Most probably BSNL will get the spectrum for 20 years. They haven’t even been officially assigned the spectrum yet. There is no transparency when it comes to BSNL spectrum allotment, I can only show it on the best guess basis, which I have done in the chart.
