@esmail what is jio’s option 6 for 5G architecture ? Do you think that jio users will experience a significant increase in data speeds if jio initially deploy Non standalone 5G considering their 4G network is already clogged ?
Speed enhancement for existing 4G users after the 5G launch will be negligible unless it comes from increased fiberisation of existing towers as an attempt to achieve blanket coverage for 5G. Users would be better off getting a 5G mobile if they want a noticeable increase in speed since the tariffs for 5G will be the same as 4G.
The jio BTS on my roof is connected with a fiber but I get much better speed on its rival. Why jio has capped DL speed at 104mbps ? Even with carrier aggregation no difference is noticed in jio. Do you think Airtel will try to touch rs300 arpu after 5g launch ?
Airtel will try to make sure they get 500 ARPU after 5G launch. For Airtel, no ARPU is sufficient unless it’s 1 lakh ARPU.
How come 5G tariffs will be same as that of 4G? Its not possible.
Cool, wait for the service to be launched and we will see who was correct 🙂
Can you tell me, Indian mmWave and US mmWave, band number is same? n260/261?
No, India will use n258/n257 for mm wave spectrum.
Hello, Esmail.
Why doesn’t Airtel have 2.1GHz band in Kolkata?
Is there any specific reason or background?
Because Airtel is a cheapskate.
Lol true!
The operators judge the load on the network depending on the data usage on a circle to circle basis and then take the decision on what spectrum to buy. Airtel may not have seen the need for 2100 MHz band spectrum in Kolkata circle.
