@esmail what will happen to Airtel in circles where the unliberalised spectrum are expiring in b8 ? How will they then provide 2G and 4G simantanously ? Or may using b8 for 4G and some chunk of b3 for 2G ?
They may renew the spectrum that’s expiring and either use it for 2G or 4G that we will have to watch. Even band 3 can be used for 2G.
@esmail I saw some 30+ % of stake in vi by government of india in Wikipedia today ? It is true ? If so will it help vi to overcome the current situation ?
I’ll only be able to reply to spectrum related questions in this comments section but you can post non spectrum related questions on our OnlyTech community forum in the relevant threads or by creating a new thread in case there isn’t one about your particular query.
