@esmail how Jio VoLTE and Airtel VoLTE differ ? Heard something cloud based VoLTE in Airtel.
@Esmail bro: What action can DOT take if any operator deploys 4G or any other technology than 2G on non-liberalised spectrum ?
They would have to pay a heavy penalty or face legal action.
